I know chainsaws are not used, (much), in ‘Fine Homebuilding’. I went to a chainsaw forum and asked my questions, but they seem to be slow as molassess answering questions there, so I thought I would come here and ask youse guys.
Youse guys know my fiscal situation already. I cannot afford to buy a new saw, nor can I afford many new parts all at once for the saw I have. Parts will have to be budgeted. I have built my own small cabin, using largely recycled materials, and am now heating it with wood from my own property. I need a good, working chainsaw to keep ahead of the firewood needs.
I have an old Huskvarna. A 380 CD. Second or third hand owner, Iyam. This thing has obviously been badly beaten about the ears by the previous owners, yet it is still going very strong. The saw is hard to start the first time of the day, but after started once, and run for about 30 seconds, it will start again anytime, all day long with just one yank.
I would like/need some information about this saw. I have e-mailed Husqvarna about what I need, but so far, no response from them. Does anyone know where I can get a parts manual for this ? And as extensive a repair manual as possible, as well. I would eventualy like to do a complete rebuild on this thing. I always buy a haynes manual for any vehicle I buy, it would be nice if I could find the same sort of thing for my husky. With the parts and repair manuals I will be able to tell if there are any missing parts, other than what is obvious. (That sharp long-tooth grabber thingy that is supposed to be on the front of the saw, parallel to the blade, is missing. As is the air cleaner.) The saw cost me 50 bucks. I had to spend another 20 on a new butterfly valve shaft for the carb, to make the saw useable. I am fully capable of servicing, and/or completely rebuilding the saw myself. With manuals in hand I will be able to buy parts a bit at a time, and eventualy to do the rebuild, (once I have all the parts.) I hope I can get a complete rebuild kit for this saw. Meantime, I yoost need some info.
What are the ‘specs’ for this saw ? ie, what cylinder displacement, horsepower, weight, rpm’s, etc.
I have been using a 32:1 mix in the gasoline. What is the proper mix for this saw ?
I am sure the blade is probably a replacement blade. I would like some info so that I can make educated decisions about replacing it again. This is what is stamped on the blade…
24893 – 3/86
23197 – 3/8
23241 – 404
2850 2966TF
Oregon
The blade measures 28 inches from the front of the saw housing, to the tip of the blade. Is 28 inches the blade size then ? Can I put a shorter blade on it ? Say 18-22 inches ? Which of the above numbers should I be looking for on a replacement blade of a shorter size ?
Husky is a word that could describe me as well, so I have no problem handling this saw. (Just for fun, just once, I cut one 3 inch branch at mid-torso height, with one hand. Yes I was very careful, and my footing was excelent.) But I would like to lighten the saw up a bit with a shorter blade. I think a shorter blade will mean less fatigue and less stress on the back at the end of the day.
Thanks in advance.
I know chainsaws are not used, (much), in 'Fine Homebuilding'. I went to a chainsaw forum and asked my questions, but they seem to be slow as molassess answering questions there, so I thought I would come here and ask youse guys.
What are the 'specs' for this saw ? ie, what cylinder displacement, horsepower, weight, rpm's, etc.
I am sure the blade is probably a replacement blade. I would like some info so that I can make educated decisions about replacing it again. This is what is stamped on the blade...
24893 - 3/86
23197 - 3/8
23241 - 404
2850 2966TF
Oregon
Thanks in advance.
