ok, yes I know you move the belt, but my crapsman drill (that still doesn’t have a working motor is stubborn. I lossened the tensioning knob like the directions say, but it barely loosened the belt, and not enough to get it over one pully onto the other. so what’s up?
Can you hold the laser level while I shave?
wrong belt....
WOW!!! What a Ride!
brand new press
the adjuster hanging up????
...... what :s
when you release the adjuster is the belt loose but won't freely come off the pully(s)???
is the adjuster an idler pully or is the motor hinged and swings in to release belt tension...
the motor swings in, except that it doesn't seem to be able to swing very far at all, mabey 3/32"
mine has a tension pulley in the middle to tighten one belt and then the motor slide in and out to tighten the other belt
try pulling the motor towards the column,
or try prying the belt off of the larger pulley first.
just unplug the darn thing first
Edited 3/31/2008 8:58 pm by maddog3
w/ screwdriver?
nothing sharp, try your hand,
just don't cut your fingers off, try pinching the belt by the outside edge and just work it off the pulley.
Start with the bigger pulley and push the belt sideways before the pulley in the direction you want it to go. When you have it pushed sideways rotate the pulley so the belt climbs off the bigger pulley. The deflecting sideways and rotating at the same time makes the belt climb off. Maybe that is it.
I'd have to go look at mine to be sure - it's been a couple years sinceI had to change it - but the knob only tights the lock down. I think after loosening the knob, i flip a lever or slide bar that relaxes the pulley so it becomes easy to change positions.
Remember as you learn machinery - never force something like this. There is always something you are missing.
I have several things that new helpers messed up by trying to force instead of taking a minute to use their brains on.
I have several things that new helpers messed up by trying to force instead of taking a minute to use their brains on.Like the time my guys hit the fence with slider tilted to 45°, and I told them to change the blade and the took the saw apart? Ei yi yi! If dogs run free, then what must be,
Must be, and that is all.
True love can make a blade of grass
Stand up straight and tall.
In harmony with the cosmic sea,
True love needs no company,
It can cure the soul, it can make it whole,
If dogs run free.
Unplug the unit
Loosen the belt adjuster
Observe the pulleys -- you'll move the belt to a smaller pulley on one end and a larger pulley on the other end. Move the end that will be moving to the smaller pulley first.
Grasp the top of one pulley and turn it by hand while you "persuade" the belt to climb up over the edge of its pully and down to the smaller pulley. Continue turning while you further "encourage" the other end of the belt to climb onto the larger pulley.
Thabks all, i figured out how, just took more muscleing than expected
You finally broke down and read the instructions didn't you ? No shame, we all have done that a time or two. That is why they include them. ;-')
speak fer yurself....
actually I read JUST that section before I posted, it literally said
loosen tensioning knob
move belt
tighten tensioning knob
this book is of no help at all
My dad got a keyless start module for his truck last Christmas. According to the packaging it installs in three easy steps!
1. Read Installation Manual
2. Watch Instructional DVD
3. Install Unit.The giver said they would pay for the installation. They were shocked when the heard it would be $400. But my dad doesn't want it. His favorite auto electrician doesn't want to touch it. Too many circuits in modern cars to mess with.
