Chief Architect for cabinetmakers
Gene_Davis | Posted in General Discussion on February 21, 2008 08:11am
This was clipped from the CA site.  Power users of Chief, please comment.  How much time will a brand new user need to be able to render kitchens and other roomscapes with cabinets, like what we see here?
And then once schooled, how much time might one take to do this scene?
I use eCabinets software, which does a super job with the mechanics of doing a build, all the buying, etc., but its onboard room-build and render package is tedious for me, and even when operated by highly qualifiied desk jockeys, cannot do a render such as this.
“A stripe is just as real as a goddamn flower.”
Gene Davis        1920-1985
    Gene_Davis | Feb 21, 2008 08:40pm | #1
    A couple samples of what eCabs can do are shown here.  I don't fault the quality of the renders so much, but doing all the other stuff beyond cabs is a little tedious, at least for me.  There is not a good library of applicances, etc.
    Furthermore, I like a wider angle of view, and it is fixed with eCabinets.
    Here is a quick sample of what an eCabs render can look like.  Building the two walls, popping in six cab units, adding applied finished ends, plus lighting, then rendering, took less than five minutes.
    Here is a rendering in eCabs by a "power user."
    Presently, I find Google Sketchup the easiest thing (for me) to use in doing roomscapes with cabs, and one big reason is the huge universe of available components one can paste right in there from the 3D Warehouse.  Fridgidaire has their entire product line in there!  A composition like this takes a couple hours.
    Taking the Google SU model into Kerkythea (a free download, BTW) can yield results like the detail seen here.  A Kerky render might take an hour to program, then up to overnight to render.
    "A stripe is just as real as a goddamn flower."
  2. MikeSmith | Feb 21, 2008 08:47pm | #2
    i can't answer your question exactly.. but i can tell you this
    my kitchen designers work with 20/20 so they can coordinate their designs with the cabinet mfr's
    our task flow ideally is like this:
    i do the structural  and room layout, with all dimensions... window sizes, beams, walls , ceiling hts , etc
    then  the kitchen designer works with my client to develop the exact layout
    once i have that .... i can  duplicate the boxes in Chief very easily.. with generic cabinets
    IF i want to ... i could duplicate exactly what the designer has... only better
    the 3d capability of Chief ..... has two cameras... one is Vector view , the other is Render view
    you build with the objects... from the objects you can do simple  ( vector )  or complex  ( render )
    with render you can add exact lighting, and a few other whiz-bangs
    the scene you show is in a render view
    render is another step, in execution and learning
    vector is always there, it's a picture ( 3d) of what you've built
    the VECTOR views in Chief are on a magnitude of  say 10 to what my designer can do with 20/20
    and  i can add things to the kitchen , like columns, correct appliances, windows, lights, under cabinet lighting ( in render )  that she can't
    the kitchen we are doing now i sold over another guy partly because i could draw tapered decorative columns that looked just like the ones in the magazine that the homeowner fell in love with  the ones the designer did with 20/20 were black boxes
    so... as far as Chief goes.... there seems to be a division arising..
     between those of us that want to concentrate on Construction Documents  with  3d capability
    and those who want Renderings with construction document capabilities
    power users who do rendering say that Chief is great at it, some export to other more esoteric rendering programs, but most stick with plain Chief
    i'm still using Vs10.08.... i'll take a one day course in  vs. X1 at JLC-live
    i'm also taking Sketchup 1 & 2 at JLC live
    you oughta put your snowshoes on and come on down
    1. MikeSmith | Feb 21, 2008 08:53pm | #3
      i'd also note this:
      Chief is so many things doing so many capabilities..
       if you were concentrating on kitchens and rendering...
       i think someone of your capabilities would be turning out stuff  like your first pic in a couple days at most
      getting bogged down in  the learning curnve has to do with the  5000 other things that Chief can do, landscape, terrain, roofs, walls, foundations, framing, import , export, layouts, layers, print controls
      blah, blah, blah....
      so. if you stuck to the chapters on cabinets &  rendering , and imported your sketchup  objects... you could be flying  pretty fastMike Smith Rhode Island : Design / Build / Repair / Restore
      PaulBinCT | Feb 21, 2008 08:54pm | #4
      FWIW Gene...I use both CA and Ecab.  I'm not remotely as good as Mike with CA but my experience has been that they are almost opposites in the sense that ECab does a fabulous job with custom cabinetry, something that I find hard to impossible with CA.  And vice versa, for your kitchen example (as you have already mentioned) ECab is tedious and limited.  I'm not sure I could replicate the CA rendering you have, again I don't claim to be in Mike's league but I'd say an experienced guy could do it in a few hours and a newcomer probably a solid day plus with all the minutiae.
      HTHPaulB
Wiring for Subpanels: The Right Cables
When running cable to a subpanel for a home addition, pay attention to the size of the wire and the amperage of the breaker.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
