clamping ground wires
BryanSayer | Posted in General Discussion on December 12, 2006 12:57pm
So some scumbucket hacked off part of the ground wire that runs from the panel to the grounding rod on the alley side.
Can I get a clamp to clamp on a new wire? Any ideas on making it less desirable?
If necessary, I’ll move it inside the fence, but that will be a pain.
I’m amazed they didn’t try to pull the ground rod up and steal that too!
    BillHartmann | Dec 12, 2006 01:10am | #1
    Put it under ground.
    Actually that is the way tha tthe code reads.
    "The upper end of the electrode shall
    be flush with or below ground level unless the aboveground
    end and the grounding electrode conductor attachment are
    protected against physical damage as specified in 250.10."
    "250.10 Protection of Ground Clamps and Fittings
    Ground clamps or other fittings shall be approved for general
    use without protection or shall be protected from physical
    damage as indicated in (1) or (2) as follows:
    (1) In installations where they are not likely to be damaged
    (2) Where enclosed in metal, wood, or equivalent protective covering."
    Hey every group has to have one. And I have been elected to be the one. I should make that my tagline.
    1. Joe Sullivan | Dec 12, 2006 01:33am | #2
      It is awfully hard to pull up a ground rod, and as it is copper clad steel, it is not very valuable.As Bill said, you should put it under ground. In answer to your other question, you can get a "wedding ring" clamp at any electrical distributor, hardware store or big box home store. If you really want to do it right, look into getting a Cadweld One-Shot to create an exothermic weld connection to the ground rod.
  2. DanH | Dec 12, 2006 01:47am | #3
    There is a section of code that at least some folks interpret as saying that the ground wire must be a single continuous piece from panel to ground rod. But in this case just getting the ground wire restored is more important than dotting the i's in code, so I'd say do what you gotta to restore the ground connection.
    If copper theft is a hazard it might be better to use aluminum wire. Don't forget to upsize the wire, though, and at least use cu/al grease at the connections.
    Under the circumstances multiple grounds (separately routed) might be wise.
    People never lie so much as before an election, during a war, or after a hunt. --Otto von Bismarck
  3. JohnSprung | Dec 12, 2006 02:23am | #4
    Sheesh -- How much wire did they get?  It's hard to imagine that they'd get more than chump change for it.  What a waste.
    -- J.S.
    1. DanH | Dec 12, 2006 05:05am | #5
      It's amazing sometimes how hard people will work to steal stuff.
      1. dovetail97128 | Dec 12, 2006 06:17am | #7
        Guy was burned to death in Portland Or. recently , trying to steal a line out of an electrical sub station while it was hot.
        ' I guess they will go pretty far.
    2. BryanSayer | Dec 12, 2006 07:17pm | #8
      Not only did the steal, oh maybe 3' worth from my house, they cut sections from the telephone pole up the street.I can't run directly underground without going through the slab - this is the carriage house. There is a panel and a sub-panel, plus the meters. I think one of the ground wires is to ground the meter box.but I can go inside the fence, which I guess I'll do. More of a pain.Even aluminum gets stolen. Our vet set up a dog run at his practice, using nice powder-coated aluminum fencing. TWICE its been broken off and stolen. Once a neighbor followed the guy who was wheeling it along in a shopping cart and called the cops.What I really want is something that detects interference, and then transfers, say 640 V to the offender. We all have our dreams.
      1. DanH | Dec 12, 2006 08:30pm | #9
        Certainly you could double-up the wires, with one of them the real ground connection and the other a sensor wire that would sound an alarm if cut. (Or put about 400V at high impedance on the second wire.)
  4. bake | Dec 12, 2006 06:09am | #6
    Use a split bolt to splice a new hunk on, should be continious.... well at least it was the day it passed inspection ;)
Double-Duty Large-Jaw Pliers
Klein's 10-in. plier wrench has a toothed V-jaw for grabbing pipe and conduit, or can be flipped around for a parallel, smooth grip.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
