Just had a bunch a foam sprayed in on a job and although they covered everything pretty well there is a few foam spots on some finished wood.
Anyone have a trick for cleaning these up??
scrape the heavy... denatured alcohol to clean the rest....
careful.. the problem can get larger quick...
ya do sanding too..
WOW!!! What a Ride!
I've had the same problem. Man is that stuff a mess. Sure do like how it works though. The techs at icynene say there is no solvent that cuts it, nothing I've tried works. I'll have to try the denatured, can't recall trying that or not.
toolin.
acetone worked for me..
Will give acetone a try. Thanks
I thought you used poly not icy
Acetone will damage your finish
