cleaning window rollers
bigbossman | Posted in General Discussion on March 2, 2007 08:15am
What is the best way to clean up old window rollers so when my windows are reglazed and installed with new ropes everything works at its best? Also do I paint them or  leave them alone?
  1. rasher | Mar 02, 2007 11:12pm | #1
    I assume you mean pulleys?
    What I did for mine was get a brash wire brush wheel for my angle grinder, brush all of the old paint off to get a a decent shine, but a little compound on to them. Then I sprayed some lithium grease or chain lube into the axles to keep turning smooth. Then I reinstalled.
    DO NOT PAINT THEM! This is what made 'em gum up in the first place.
    My pulleys are not brass, I think they're just plain old iron. To prevent any surface rust, I brushed some plain 'ole linseed oil over the exposed surfaces and let it dry for a couple of days.
    If the rust comes back, I'll just steel wool the spot and re-linseed oil and be done with it.
