Hey my final question for today 🙂 im stripping paint of the trim (mould) im using they soy gel is it ok to clean it with say bleach and water or soapy water? after i get the majority of the paint off im want to use a sponge with a slight abrasive end and wash it down before i do the final sanding and prime and paint. Basicall what can i use to clean the wood trim with?
If you have bare wood and are priming with latex, go ahead and clean with water. Just dust it off good first, vacuum it if you wanna get crazy. Cleaning with water dampens the wood which helps to draw the primer in. Something about the primer displacing the water as it evaporates within the wood, and it opens the grains a bit helping with primer adhesion. Give the prime coat a nice sanding and cleaning before putting on the first coat of paint.
Are you priming with oil? If so you might want to go about it differently. Clean with paint thinner? Tack cloth? Hmmm.
Im using a paint thinner called soy gel it has almost no odor and is great. the best pain remover ive ever used. im going to use latex not oil. I just wanted to make sure its ok to use water to clean the bare wood after i strip it and it would damage the wood in any way. is just soap and water ok or wqater and bleach or it doesnt matter
Didn't know that about the latex primer with the evaporation adhesion. Good post.
How do we dance while our world keeps turning?
How do we sleep while our beds are burning?
How do we eat with our belly's churning?
Regardless, learning, always learning.
damn, am I fat!
