Hello there,
Without getting into all the details do you think that I can drain a new clothes washer between joists which is approximately 6′ 6″ in height?
Thanks for responses,
Dennis
Hello there,
Dennis
Most washers can pump to 8 feet or so, even though the specs may say lower.
But what is the height of the drain?
IIRC the top of the standepipe needs to be 30" over the trap. Otherwise the standpipe might overflow.
I doubt that if you have a GOOD CLEAN drain that you need 30", but you still need some measurable amount over the trap.
I've never seen a joist that tall
you need to get out a little more and work some commercial jobs...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
I have never seen a between the joist drain.
at that hieght and if yur washer can lift that high..
make sure you put a check valve in the whasher's drain line as close to the mavhine as you can get or the washer may never empty..
WOW!!! What a Ride!
