I have a question on Coffered Ceilings. How do you center them with a bay window? We have a bay window in our kitchen. If we put the ceiling up centering it NOT taking into account the windows, then the beams are off in window. One beam will be on a corner of 1 window, and one beam is 2 inches off of the main window, and no beam on the 3rd window.
Thanks for any advice..
Kim
If you need to fudge a section size by an inch or two nobody will notice. The bigger the sections the less noticable. Just as I'm pretty sure nobody would notice what you are describing
If the only person who knows of a descrepancy is the guy with the tape measure then let it go
I agree with Maverick. Change the spacing so that its not exactly even, but so that is matches the other design elements better.
The only way that anyone will notice is if you are putting something in each 'tray', every one of which is already pre-sized to be the same size. Even then, it would be an odd person who noticed.
Unless you're the lead dog, the view just never changes.
