Cold weather, freezing weather
| Posted in Construction Techniques on January 20, 2003 12:53pm
Hello guys, It’s been a long time, 6-7 years, since we have had Alberta Clippers hang around Maryland this long.  Does anybody have an opinion on how cold would it have to get and how long would it have to last to heave a footing on a crawl space addition, 30″ deep with 4 courses of 8’s and 2 x 6 frame one story, truss roof.  Framing complete and shingles about to be installed.  Let me have all of the horror stories now so I can prepare.  My guess is that it would have to be in the teens for a least a week and even then I think I have the weight to hold it down.
  1. r_ignacki | Jan 20, 2003 03:06am | #1
    we're in va, how about if the temp is constantly freezing, the ground would freeze about 1" per day, sound about right?
  2. TedStaples | Jan 22, 2003 06:23am | #2
    Soil conditions? Is this backfilled? It's dosen't seam as if you are any danger, am I missing something?
    If it's open why don't you hay the areas down you are worried about?
    BossHog | Jan 22, 2003 04:30pm | #3
    I think it would depend on a lot of things. Like snow cover, for instance. Snow can keep the ground from freezing so deep. And how warm the ground was before it turned so cold. And how fast the ground tapers away from the foundation.
    I think it would take sub zero cold for quite a while if there's any snow at all.
    Give a man a fish; you have fed him for today. Teach a man to fish; and you can sell him fishing equipment.
  4. Turtleneck | Jan 22, 2003 05:03pm | #4
    Coming from the frozen north, I would say it would take a solid month of 5° to 10° F weather to freeze that deep and another two weeks to freeze below that depth and cause a heave. The weight you are talking about would not stop a heave if it were to occur. I've seen a two story addition lift 3" on a DIY foundation. They were wondering why the patio door wouldn't close properly. Of course that was after 2 solid months of sub zero temps and there was a spring running under bedrock near the NE corner of the addition.
    ( your logo here) Turtleneck
  5. Remodeler | Jan 22, 2003 05:06pm | #5
    Here the ground freezing to the frost line (36") is considered a ten-year event.  (midwest, very cold january's and february's).  However, if you've ever dug in the winter bare dirt freezes quick, and dirt under concrete seems like it would never freeze.  Under turf, again, a ten-year event.  So if you're real concerned, get some mulch and build it up on either side of your block foundation - that's the 8's? - about a foot wide on either side.  It will do more than raise your frost line - it will also hold heat in the ground.
    remodeler
    1. Mdbuilder | Jan 22, 2003 11:25pm | #6
      The mulch is a great idea, cheap to, and for the most part it can be reused, great idea.    Thanks
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
