Compressor hose
| Posted in General Discussion on April 6, 1999 02:58am
I have a compressor that at 40 psi it has 8.6 cfm. I want to use an air drill, nail gun. Some folks say only 1/2 hose others say 3/8 will do. I believe i will be using a maximum of a 100 feet of hose.
Any brands of hose that work better? Comments on 1/2 versus 3/8. suggestions? I live in California so freezing is not a big issuse.
  1. Guest_ | Mar 18, 1999 02:15am | #1
    I have never heard of 1/2" air hose for small tools. The choice is always 1/4" or 3/8". Larger hose is better for continuous demand tools, such as air chisels, where you need good flow. Smaller hose is better for intermittent demand tools, like nail guns, where you need constant pressure.
    1. Guest_ | Mar 19, 1999 04:26am | #2
      *Just ran to the shop to check my hose size. It is 3/8". Never heard of 1/2" but maybe someone does sell it. As a practice I always get my compressor within 50' of the nailing site because I don't like snaking all the loops and kinks of a longer hose.
      1. Guest_ | Mar 19, 1999 05:48pm | #3
        *Go 3/8ths. With 3/8ths couplings.
        1. Guest_ | Mar 20, 1999 06:01am | #4
          *I've got 3/8ths and wish I had gone with 1/4. Less bulk and cheaper fittings.
          1. Guest_ | Mar 20, 1999 08:30am | #5
            *Air drills, and other tools that use lots of air need much more continuous air then nailers do...I know cause I build docks and work underwater with all kinds of airtools...3/8" hose works but I have 1/2" too and use it for all the high air demand tools including a custom 12" spike driver I made.Roofing with 1/4" lines...nice and light!J
          2. Guest_ | Mar 23, 1999 10:09pm | #6
            *Kind of thought you might be the kind to use an electric drill with grounded drop cord for that underwater stuff.Dennis
          3. Guest_ | Mar 24, 1999 08:50am | #7
            *DennisTried that but its hard to let go of the trigger!!!Near the stream using air,J
          4. Guest_ | Mar 24, 1999 09:24am | #8
            *Must be nice not having the freezing hoses in california... here in Chicago seems that the 'blue stiffie' never gets rolled up in winter!!
          5. Guest_ | Mar 26, 1999 03:14am | #9
            *Kerry: I agree with everyone who distinguishes between continuous demand (drills, sanders, grinders) and intermittent (nail guns). At 8.6 cfm, I calculate the pressure drop in 100 feet of 1/4", 3/8", and 1/2" hose as 112 psi, 15 psi, and 4 psi, respectively. Half that much pressure drop for 50 feet of hose. So clearly 1/2" is plenty big enough and 3/8 is okay unless you are working at low pressure (10-40 psi) because while your regulator will maintain the set pressure at the A/C outlet, the distal end of the hose will vary with flow rate. And 1/4" is just to small to run multiple tools. Okay for one nail gun, but then your average flow isn't usually 8 cfm.
          6. Guest_ | Mar 26, 1999 10:21am | #10
            *"distal end of the hose"?
          7. Guest_ | Mar 26, 1999 06:18pm | #11
            *In California we work so fast that the hoses freeze solid from the expanding air.
          8. Guest_ | Mar 26, 1999 07:44pm | #12
            *Let's see, David, 1/4" hose @ 100 feet with a supply pressure of 100psi and 112 psi drop....can I use for a shop vac?
          9. Guest_ | Mar 30, 1999 01:44am | #13
            *Sorry, Fred. My wife's an MD and sometimes the jargon is contagious. Your fingers are the distal end of your arm. Opposite of proximal. One new "medical" term: suboptimal, used as an understatement. Example: "The patient took aspirin ( a blood thinning stomach irritate) for his bleeding ulcer pain. That was suboptimal self-treatment."Mike: My calc for pressure drop in 1/4 hose was just to show that it was undersized. It couldn't actually flow at 8 cfm unless more pressure was applied. But, yes, you can use compressed air as a shop vac. Venturi are available to create high vacuum (you may have used a water-powered venturi as a vacuum pump in chemistry class) and other styles of nozzles use compressed air to induce flow in a larger volume of air and can function as vacuums or blowers. Handy in potentially explosive environments where you want to avoid the use of electric motors.
          10. Guest_ | Mar 30, 1999 01:36pm | #14
            *We're sounding more and more a like jack!I use 1/4" for as much as possible.I used my 3/4" drive wrench to set some lag bolts underwater, and it rusted up! Of course I had to buy a newer better one.How do you keep the tools from intaking water?Blue
          11. Guest_ | Mar 30, 1999 10:26pm | #15
            *Probably that would be appropriate after Blue had Chili Dogs for lunch.Dennis
          12. Guest_ | Mar 31, 1999 02:32am | #16
            *Hey!!!Blue
          13. Guest_ | Mar 31, 1999 05:23am | #17
            *Now that I think about it, I have picture of myself, standing in chest high water using my Milwaukee 3/8 drill, parallel to the water drilling some holes. Guess the ground cord was in good shape.Dennis
          14. Guest_ | Apr 01, 1999 04:48am | #18
            *David:I knew what you mean't but it was such a strange term in this context that I wasn't sure you did:-)
          15. Guest_ | Apr 03, 1999 10:25pm | #19
            *Now who would have thunk that a thread started on air hoses would break down into "wordsmithing" with medical lingo!!! I too have a group of medical friends and am just learning to understand their unique vernacular...Near da stream I be,J
          16. Guest_ | Apr 04, 1999 03:07am | #20
            *Blue,I use lots of oil just after the tools come out of thwe water to clean them out...Their is biodegradable oil availabe now for the tree huggers too.Near the stream and lovin my air chainsaw,J
          17. Guest_ | Apr 05, 1999 11:59pm | #21
            *I oiled the crap out of mine, but it wusted up anyways. I took it apart, fixed it, but it froze again a year later.Maybe your water is better!Blue
          18. Guest_ | Apr 06, 1999 02:57am | #22
            *Blue,I have had one 3/4" impact brand that would seize too easily but the rest of the scuba diving tools have worked fine for over ten years....I leave em oiled and do check one last time before I toss them on the shelf to get dusty...Love shooting 16s under water...thunk!...thunk!..watch out James Bond...Near the stream, cutting down half my neighbors trees,JIce out yesterday in Lake George and headed out now to do a damage estimate...water temp around 35 degrees.
