I need to pour a concrete slab in an addition. Finish floor will be tile. About 500 square feet.
I need to mix the mud on site and work alone with 1 helper so will not be able to complete the pour in one day. so the question is:
should I tie the seperate slabs together with doweling in addition to the continuous wire mesh? If so, how frequently? Then I guess I should use some sort of isolation barrier between the slab and the tile.
Thanks for any advice.
Greetings bo,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Parolee # 53804
