I just saw some ownerbuilt homes in Utah made from a concrete/styrofoam block product (approx. 16 in. X 16 in. X 60 in.) which is glued, then concrete is pumped into the center cores.
This stuff is light, easily cut with hand or power saws and has a reputed R40 insulation rating.
The people I talked to said the product is called Rostra (or something which sounds like “Rostra.” They thought it was manufactured in Colorado–and perhaps other places too.
Has anyone heard of this? Thanks for any help you are able to provide. –Ron
A standardized approach, quick-to-install hardware, and a simplified design make building custom casework cost-effective.
Sounds like Conform phone/fax (714)459-8858
Once framed a roof on a house that used that
system or one similar to it. The home owner called it iceblock. Hollow styrofoam blocks with rebar
running vertical and horizontal through the voids,
then filled with concrete.
Heard later that the homeowner had problems with
water in the basement. Guess not all the voids got
completely filled with concrete.
my one time experience,
Mike Merisko
The name of the product is Rasta, it is an ICF, insulating concrete form. For more info on Rasta and other ICF's go to:http://insulatingconcreteform.com
you will find the address and number for Rasta also people who build with it.
Rob Dykeman
*Rob, I believe that you recommended ICF's to me last week for the basement walls of a summer cottage I'm building. If so, thanks - I'm looking seriously at "Blue Maxx" ICF's. Does anyone have experience with this particular system?
The people I talked to said the product is called Rostra (or something which sounds like "Rostra." They thought it was manufactured in Colorado--and perhaps other places too.
Has anyone heard of this? Thanks for any help you are able to provide. --Ron
