Although there are similar questions out there I did not want to jump anyones thread. I have gutted (to the rafters and wall framing) the second floor of our 1850’s cape in preparation for a new master bed/bath. Like some other houses described, the rafters are small (3 by 4’s) spaced 3 feet o.c. approx. There is a ridge vent but the soffit vents were closed over by a vinyl siding job. No insulation in roof or walls. The house is built well but I’m sure it has an air leak or two. The question is, what insulation works best in old houses where finding the all the leaks might not be possible? We are looking for good R value and superior sound deadening. Should I open the soffit vents too? We are in Maine are worried about condensation on the inside of the sheathing when we heat the second floor. Thanks in advance.
J
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
J
I would sheet over the rafters with foil-faced polyiso foam board from ridge to rafter plate and blow behind it with densepacked Cellulose. Don't try to insulate down the kneewalls. Keep everything under the rafters within the thermal envelope for better/easier air sealing.
Good airseal and the densepacked cellulose obviates the need for venting (unless maybe you are talking black shingles in texas), though your codes office may not see it that way.
Good luck.
Steve
Although there are similar questions out there I did not want to jump anyones thread. I have gutted (to the rafters and wall framing) the second floor of our 1850's cape in preparation for a new master bed/bath. Like some other houses described, the rafters are small (3 by 4's) spaced 3 feet o.c. approx. There is a ridge vent but the soffit vents were closed over by a vinyl siding job. No insulation in roof or walls. The house is built well but I'm sure it has an air leak or two. The question is, what insulation works best in old houses where finding the all the leaks might not be possible? We are looking for good R value and superior sound deadening. Should I open the soffit vents too? We are in Maine are worried about condensation on the inside of the sheathing when we heat the second floor. Thanks in advance.
J
