Connecting Ledger Board to House
| Posted in General Discussion on June 14, 2001 06:17am
I’m building a deck off the second story of our house. Talking to a building inspector today, I cannot tie the ledger to the blocking that I installed (when the house was still in framing) between the 2nd floor joists. The inspector said I must tie to the framing, either above or below the floor joists.
Any suggestions for how best to meet their requirements? If I tie to the 2nd floor framing, then the deck will be too high. If I tie to the top of the 1st floor framing, I am afraid I’ll be too low. Also, all the framing is covered with stucco (on the outside) and dry wall (on the inside). Any thoughts regarding how to locate the framing without tearing everything apart?
  1. Jim_Walters | Jun 14, 2001 02:22am | #1
    I may be missing something here, but your second floor joists should be nailed into a 2x10 rim, (that would hold the anchors for your ledger board) . . .then the ply floor, above the floor sits the door to your proposed deck. Right?
    Even a ballon frame would have long studs to anchor into. How'd you frame that guy anyway ?
    1. Mark_Pedro | Jun 14, 2001 06:17pm | #2
      *Jim ---Re-reading my message, I was a little unclear. The code says I cannot tie only into the rim joist. I think the solution is that I have to use a wide ledger (2x12) and drop it down enough to hit the top plate in addition to the rim joist. Thinking it through a little more, it's not that big a deal, I just didn't want to use such a big ledger... that's a lot of wood.Thanks for your comments!--- Mark
  2. Mark_Pedro | Jun 14, 2001 06:17pm | #3
    I'm building a deck off the second story of our house. Talking to a building inspector today, I cannot tie the ledger to the blocking that I installed (when the house was still in framing) between the 2nd floor joists. The inspector said I must tie to the framing, either above or below the floor joists.
    Any suggestions for how best to meet their requirements? If I tie to the 2nd floor framing, then the deck will be too high. If I tie to the top of the 1st floor framing, I am afraid I'll be too low. Also, all the framing is covered with stucco (on the outside) and dry wall (on the inside). Any thoughts regarding how to locate the framing without tearing everything apart?
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
