copper flashing
ktkamm | Posted in Construction Techniques on June 21, 2007 11:55am
I am attempting/planning to install some copper flashing that will cover the board that sits on top of my return (replacing exterior trim. Should I attempt to solder the corner joints or just use finish nails. The board the copper is to sit on is only 3/8″ thick. If holding edge in place with nails, is it ok to use the copper plated nails? If soldering is the way to go, any tips/techniques? Thanks in advance for any help.
Kieran
  1. seeyou | Jun 22, 2007 01:18am | #1
    The best way to do this (IMHO), is to install a copper drip edge fastened with copper nails on the two open sides. The copper to cover the return roof should turn up the wall (and then counter flash with a separate piece) if that condition exists and/or slide under any rake trim that lands on the return roof. The copper should protrude a 1/2" or so past the top edge of the drip. Fold that 1/2" back under and squeeze it to the drip edge.
    Copper expands and contracts quite a bit. Leaving a flat lock on the outside edges lets it move. Do not face nail it. Expansion/contraction will open the holes around the nails up and allow leakage. Using dissimilar material nails will cause electrolysis and usually the nails will disappear after a while.
    As far as soldering, I haven't seen a cornice return I can't cover with copper without having to solder. Think out your pieces if you need more than one and fold them together so solder is not necessary.
    http://grantlogan.net/
    Sometimes, when I lie in bed at night and look up at the stars, I think to myself, "Man! I really need to fix that roof."
    1. ktkamm | Jun 22, 2007 07:28pm | #3
      Thanks for the input. I will try to fashion something together this coming weekend.
  2. WayneL5 | Jun 22, 2007 04:23am | #2
    It's not ok to use plated nails, they won't last.  You have to use copper nails.
    1. ktkamm | Jun 22, 2007 07:29pm | #4
      Any suggsetions as to where to get copper nails? I have found larger ones for roofing, however can't find any small ones.
      1. seeyou | Jun 22, 2007 08:19pm | #5
        You are roofing. Use roofing nails.
Choosing a Paintbrush
  • The New Old Colonial
