Corian sink plumbing ?
Danusan11 | Posted in Construction Techniques on April 4, 2005 01:33am
Customer switched out some cask iron vanitys, for new corian counters and undermount sinks.
Question
Existing tailpiece will not work, as cast iron had a hub on bottom and overflow was able to go up inside and tighten down. The new corian are not nearly as deep at bottom, so overflow is exposed. Is their a special tailpipe used for corian.
Can I use plumbers putty or do I have to silicone drain flange
  1. USAnigel | Apr 04, 2005 01:57am | #1
    Corian would like you to use silicon, plumbing putty might stain around the drain. Tailpipes are not special for corian.
  2. ScottMatson | Apr 05, 2005 04:17am | #2
    It should have come with a plastic overflow tube that is usually siliconed onto the sink. It's a lot easier to install this before you put the sink in. My plumber hates these things but we do them all the time.
    1. Danusan11 | Apr 05, 2005 04:20am | #3
      Thats what was missing, fabricator dropped it off today.
Drafting the 2027 IRC
  • The New Old Colonial
