Corission problem
und76xx | Posted in General Discussion on March 10, 2011 02:48am
I have a two story home located in Michigan.  Most – if not all of the faucets in the three bathrooms and in the kitchen are crome.  In the basement the bathroom sink, a sink in a small kitchen area and the sink drain apparatus are crome or stainless steel.  The faucets/sink drains in the basement show signs of pitting, corission or something like that.  The handle on the toilet in the basement almost fell apart because of – not peeling foil – but actual loss of metal structure.  (Its an older toilet with real metal handle)  This problem only exists in the basement.  Any idea why?
The house has a natural gas furnace.  The dryer is in the basement and is also natural gas.  I have CO detectors throughout the house and they have never sounded an alarm.  I do not do any chemical ‘stuff’ in the house or in the garage.  I do have any welding equipement.  The soap I use is the same both in the basement and in all other bathrooms in the house.
Ideas?
Thanks, Mike
    MarkH | Mar 10, 2011 04:25pm | #1
    Most basements are higher in humidity than upstairs, so I suspect the basement plumbing is damp from condensation more of the time than upstairs plumbing.
  2. Scott | Mar 10, 2011 06:54pm | #2
    Probably a combo of old age, high humidity, and cheap fixtures.
  3. DanH | Mar 10, 2011 07:51pm | #3
    It's cooler and more humid in the basement, so condensation forms on metal surfaces, especially things like plumbing fixtures that are cooled by water flow.  I doubt that your gas appliances have anything to do with it (unless you vent your dryer into the house), but it could be that acid water is a contributing factor.
  4. DanH | Mar 10, 2011 09:51pm | #4
    Very often the cast metal handles on cheap faucets and the like are made from "pot metal" -- a zinc alloy that readily corrodes, especially when in contact with other metals.
