Please take a look at the attached (I hope) drawing of my workshop I’m building. I cannot figure out if this trim piece should go here or if it should be left off.
S
S
Learn about solutions and fastening methods to prevent truss uplift issues.
Maybe this will help you get some answers
What IS that area? It looks like it might be a covered porch, supported by a post on the corner.
If so, why do you need a short wall section between the main building and the post?
Leave that mini-wall out, use corner trim as usual and flash and install header trim to match the real windows and supply a stop to the soffit.
yes, use the corner board trim
did U just run out and build that because sketches are so hard to read?
Jeff Buck Construction
Artistry In Carpentry
Pittsburgh Pa
ROFLMAO!!!!
I was thinkin` the same fargin` thing!!!
"Scuse me while I step outside for a moment.....voila."
Lemme get this straight....
YOU BANNED REZ?!?!
Holy bagels and lox Batman!
dat's a ROAR!
