FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Covering the bottom of a cantilever
faderUS | Posted in General Discussion on December 12, 2020 10:37am
I have a typical 1960 raised ranch with a 24” cantilever extending out across the front of the house.  The current panel on the bottom of the cantilever has popping paint, is coming loose in places and just looks crummy.
I want to install a couple of flush electrical outlets in this area and clean it up while doing so.  Is there any reason not to pull the existing material and use this to replace it?  Is there a better product?  Right now it appears to be 1/4” ply of some sort, and is skinned with metal on the section above the garage doors.
https://www.lowes.com/pd/LP-LP-Multi-Use-Panel-Application-As-4-ft-x-8-ft/1002550422
  1. bing0328 | Dec 12, 2020 11:00am | #1
    I would consider using Hardiboard sheets (1/4x4'x8'). The Hardiboard acts like stucco so paint adheres and lasts. It is also fire resistant so if you are in or near a fire zone it acts as a deterent. Use galvanized nails to install.
    1. faderUS | Dec 12, 2020 11:32am | #2
      Isn’t LP Smartside a direct hardiboard alternative?
Exterior Materials for a Midcentury Home
Travis talks with the architect about his thought process for choosing the materials that create a functional and seamless aesthetic for this house.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • 2024 Tool Guide
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
