In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Cracked bath tub. What to do?
| Posted in General Discussion on December 2, 2002 07:14am
I just moved into a new house and discovered that the fiberglass bath tub has two cracks in the bottom of the tub where it curves to meet the side of the tub. This is a one piece unit, and there is NO way to remove the tub the way it was installed. It will have to be cut out and a two piece, or three, or four, will have to be installed. I don’t know what the builder is going to do about this and am wondering what my options are. I sure do not want a “patched” tub in a new house!!!
  1. suntoad | Dec 02, 2002 09:24am | #1
    You sure the tub is actually cracked and not just the enamel gel-coat?  Does it leak?  Becasue it's the bane of acrylic tubs that the enamel "gel-coat" cracks--usually at installation if the installer is not REAL careful.  If it is just the enamel, it' a mere cosmetic problem, but it can be be fixed--there are even tub repair specialists in the yellow pages who do just that.  Or you can leave it be.  It will no doubt crack again, probably in the same place.
  2. RalphWicklund | Dec 02, 2002 09:34am | #2
    Hop to it and present your findings to the builder. A tub that is cracked before you use it is unacceptable, in my book. Have you gone through the punch list with the builder? Do you have a punch list? There is no such thing as "NO way to remove" or having to settle for a multipiece unit as a replacement. Case in point: I designed and built a custom bathroom with a special oversize cultured marble whirlpool style tub. This tub was set between a tile and glass block shower, a vanity end and two adjacent walls and then the wall and floor tiles were set. It took two men and a boy just to carry it in and set it. It cracked, just like yours, but right at the end of the one year warantee. The fabricator, whose people installed the tub, pulled that monster out and put in a new one, damaging (and replacing) just a few tiles. No charge. Don't let anyone tell you something can't be done.
Systems and Products for an All-Electric Small Home
Choosing windows, doors, HVAC, plumbing systems, and finishes with sustainability and healthful materials in mind.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 462: PRO TALK With Construction Attorney Karalynn Cromeens
  • A Practical Approach to Installing Windows
  • Cordless Drywall Cut-Out Saw
  • Podcast 461: Adding a Screened Porch, Insulating a Raised Addition, and Preventing Termites in Exterior Foam
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Tool Guide 2022
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
