I have a 16′ X 28′ timber frame camp built in Maine with a concrete perimeter foundation to below frost with a earth floored crawl space. The building has perimeter drainage on the outside and
around the interior perimeter of the foundation. I have insulated the floor with 6″ of fiberglass and
have put poly on the surface of the earth floor. I am getting water on the surface of the poly that
appears to be condensation. What can I do, if anything to eliminate this problem? At present the
joists, and sill appear to be dry and the moisture is only on the poly covered floor.
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
I have a 16' X 28' timber frame camp built in Maine with a concrete perimeter foundation to below frost with a earth floored crawl space. The building has perimeter drainage on the outside and
around the interior perimeter of the foundation. I have insulated the floor with 6" of fiberglass and
Margaret,
The water on the surface of the poly could be from a dozen sources and by itself is not cause for worry. You may want to check for leaks.
If the rest of your basement structure is dry, a little water on the poly will not hurt anything. Just monitor it at different times and unless there's an increase in the moisture level, do enjoy your camp.
Gabe
