I was going to use drycon does anyone gave any better suggestions?
thanks
Greetings malibuds,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Let's run this thru again.
bump
What is drycon?
What are you trying to "seal" the crawlspace walls? floor?
Seal against what, moisture, water, air?
Thanks for the reply but plans changed to a basement . I am now going to use Rub-r-wall against the walls for moisture. Hopefully no one has had any problems w/ this.
thanks again
