Recently I installed a cultured marble top on a vanity and had to shorten one of the end splashes what is the best tool to cut this product with.
Carbide blade on the skill saw or miter saw will work. I would just use a jigsaw and cut the end that wont show.
What kind of blade do I use in the jig saw the cut has a slight radius. I have a Bosch jig saw.
Ive used both fine and coarse wood cutting blades for this. The fine makes a little better cut but the corners are usually caulked so a little chipping is ok. Its not really hard to cut. Id cut from the back side so the saw base doesnt scratch it.
Make up that radius with a bench secured belt sander, back bevel the splash too while you're at it for a tight fit on the counter.
Quittin' Time
