In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Curcuit short
csmeutah | Posted in General Discussion on October 16, 2005 07:38am
So the lights went out in the kitchen today, breaker kicked off.  The house is 12 years old, there are two other rooms on the circuit.  No changes to the wiring recently, no event connected to the breaker popping off.
I removed light bulbs in the kitchen (6 spotlights in cans) and hardwired the switch, breaker still goes.  I would suspect the breaker but the other lights and a fan work fine, it seems to be just the one switched part of the circuit.
What’s the easiest way to track this down?  I’ve wired a number of houses but not much debugging.
Thanks in advance,
  1. Piffin | Oct 16, 2005 07:58pm | #1
    hardwired switch? Does that mean bypassed it?
    Any chance this circuit runs through a GFCI?
  2. WayneL5 | Oct 16, 2005 08:31pm | #2
    The easiest thing to check first is to shut the power off at the breaker then remove the covers from all the boxes in the circuit and look for evidence of shorting.  This would include outlets, switches, light fixtures, and junction boxes.  If it is not there, it could conceivably be in the wiring somewhere.  It is possible (and I have seen it) where a nail gets driven into wiring and then over time as the wood moves the nail moves just enough to short out.  The only way to find that is to disconnect portions of the circuit in a logical way and isolate the portion that has the trouble.
    Breakers do go bad occasionally, but it is more likely you have a problem in one of the boxes.  To test the breaker you'd hook the hot from that circuit to another breaker and see if it trips the other breaker, too.
  3. CAP | Oct 17, 2005 12:39am | #3
    Do you have an ohm meter (better) or continuity tester?
    Do you know how to use it?
    If so, employ a basic rule of troubleshooting--the rule of halves.
    Start at the panel or the first outlet in the circuit, free the conductors (break any splices or remove from terminals) and test for a short between the hot and neutral and hot and ground.  I expect that you'll find a short.  If not--replace the breaker.
    Let's assume it is indeed a short circuit.  You've already isolated the section of the circuit with the short.  So, then guesstimate the half-way point in that section.  Open up the outlet, switch, or fixture box, at the mid-point and break the splices for all the conductors, and check resistance or continuity between hot-neutral and hot-ground  in each direction.  There will probably be only one short.  By splitting the distance each time, eventually you'll find it.  Often much more efficient that opening up all of the devices and fixtures before you start testing.
    Keep in mind that in pulling the receptacle or switch out of the box, you may be removing the short.  But there'll often be evidence of it--some soot, arc tracking, or metal splatter on a wire or a terminal screw.
    Keep in mind that this testing has to be done with power off.  And that in some situations, more than one circuit runs through a box.  Use a non-contact voltage tester as a screening tool, and a contact voltage tester (NOT a digital multimter, which can be fooled by phantom voltage, energy that bleeds over from an adjacent live cable, due to capacitive coupling) every time you open a box to make sure the wires are not energized.
    Good luck.  If you're uncertain about how to work around wiring in a house that's got power to it, call a pro.  It's easy to get into trouble--to get so focussed on troubleshooting that you forget about an energized wire, and get shocked or electrocuted.
    Cliff
    Edited 10/16/2005 6:45 pm ET by CAP
    Edited 10/17/2005 11:27 am ET by CAP
Tools for Managing Home-Building Financials
Production manager Ian Schwandt explains how financial tools such as QuickBooks or Buildertrend can help companies track project costs for a healthy outcome.
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
  • Track Lighting for Functional Ambiance in Busy Spaces
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
