curved deck boards
mpwangler | Posted in Construction Techniques on July 19, 2006 03:50am
I am about to put a deck partially around an above ground pool.  The pool is 24′ and I would like to run the deck boards parallel to the pool edge in a curve.   From above the deck would look like a rainbow pattern.
I have a bunch of 16′  Certainteed board walk synthetic deck boards that are 5/4″.  My plan would be to place these in the sun on a hot driveway and then shape them around the pool.  I suspect I’ll have to use some clamps expecially as I fasten down the last part of the board.
Has anyone ever done this?  I would be interested in techniques and hints.
Thanks,
Michael
  1. mikeys | Jul 19, 2006 04:12pm | #1
    This months issue of JLC has an article about bending Trex. I think he heated it to 260 degrees. And he was bending it the other direction (on the flat, not on edge as you want.) Good luck.
