WHAT IS THE BEST WAY TO ENLARGE AN OPENING IN A TALL CABINET? THE OPENING FOR THE OVEN UNIT IS TOO SMALL. THE CABINETS ARE FRAMED CABINETS MADE OF CHERRY.THE CABINET HAS BEEN INSTALLED.
How neat does it have to be? usually a lip covers a good half inch all around. if you are worried about damaging the cabinet, my favorite tool for this kind of surgery is a router. just jig up some type of straight edge to guide the tool, and you will get a nice smooth cut without a lot of stress on cabinet frame. For quickest work, a jig saw would be faster, though. You may have to remove doors on nearby cabinets to have a flat enough surface to run the tool along.
*Hi Mack, I was just wondering is the opening too small on all 4 sides or 2 sides only. If the opening needs to be taller, and depending on how the divider rails were installed it may be possible to carefully remove a rail and down size it on the table saw, then reinstall it into the face frame. If that isn't possible Rich's method sounds like the way to go. MDM.
*Mack,At the risk of sounding rude.........If you have to ask, you might want to hire a carpenter.Ed. Williams
