Your right with the masonry blade. Just finnished a fence job on asphalt which we had to cut 1’sq. holes and it worked fine.
Listeners write in about greedy dormers and shop class and ask questions about steamy storm doors, fireplaces, and insulating a basement.
I need to cut out a large chunk of an asphalt driveway. I'm assuming that I can break it up with a jackhammer, but I'd like to be able to make a relatively smooth cut along the new edge. Any suggestions?
jeff
*Your local rental outfit should have a handheld gas powered saw for this. IT's worth the cost to get a clean cut. I cut out the edges, the knock the center ing pieces. This makes for a much nicer patch when filled back in.
*Depending on how large a chunk, you also may be able to make a pretty clean cut with an asphalt cutting bit in the jackhammer - a relatively thin blade about 3-4" wide, if your rental shop has one. You can cut out a square corner, for instance, which you can't do with a saw. If your large chunk involves a long straight line, the walk-behind saw is better.
*Masonry blade in circular saw works fine for cutting asphalt provided you don't have to cut too much of it.
*I've had sucess using a diamond blade. Costs a bit but works great. Derek
*Your right with the masonry blade. Just finnished a fence job on asphalt which we had to cut 1'sq. holes and it worked fine.
