I’ve seen 2 techniques for cutting rafters, one measuring along the bottom and the conventional across the top way. Measuring along the bottom seems alot easier and accurate. What do you guys think
Patrick chats with the BS* + Beer crew at this year's International Builders' Show.
I think that you should use whatever method works FOR YOU
Neither method is any more or less accurate than the other. Whatever you're comfortable with.
Chainsaw baby YEAH!!!
I'm a "conventional" guy.
blue likes to use his speed square though.
J. D. Reynolds
Home Improvements
It all depends on which side you want more accurate.
If you want the ceiling flat, layout from the bottom.
If you want the roof flat and the bottom of the rafters are buried in the attic, layout from the top.
Don't use a speed square either way, unless you just want marks that are "suggestions".
blue
Common rafters go from the outside of the wall to the ridge. The plumb cut lines are parallel so there isn't any difference in length between top and bottom. The seat cut is marked from the bottom, the length of the overhang cuts, plumb and level, are determined by the fascia and soffit details. We always sight the rafter stock and place any crowns up. I still mark out a pair of rafters and try them for a fit. If I didn't goof, I use the first one as a template to mark out all the others. Keep the tops flush at both ends, any variance in the width of the rafter stock is compensated for, although lumber doesn't vary all that much anymore. One more reason New Englanders use strapping. If there is variation in width of the materials, the strapping can be shimmed for a nice straight ceiling.
