Cutting tiles w/o cutting fingers
JMadson | Posted in Construction Techniques on January 20, 2008 06:21am
I’ll be completing a tile backsplash this afternoon – 16 sq ft total. The tiles are 1″x1″ slate (1 sq ft to a sheet). I have a $99 tile cutter from HD that has served me well the last two projects (it may only have one, maybe two projects left in it though).
Any tricks for cutting small tiles without getting my fingers in harms way?
  1. MFournier | Jan 20, 2008 07:32pm | #1
    If you are using a tile saw there is little danger to your fingers. You really need to hold you finger on a tile saw blade a long time or with a lot of pressure to cut it. The diamond blades on tile saws just do not cut skin very well.
    Depending on the type of saw you are using it is holding the small pieces from getting caught on the blade and send a small piece flying in your eye. so fingers not much danger proper eye protection a must.
    1. calvin | Jan 20, 2008 08:23pm | #2
      If you trap your finger or other body part between the blade and something hard like the tile of tray, it will probably get cut.
      For those tiny bastards I hold both sides of the tile with a finger on both sides, bridging over the channel in the tray.  This keeps the tile under control when it cuts through, keeping it from falling into the channel.
      If I can balance most of that small tile on one side of the channel, then that's what I do.  The cut off usually won't bind up in the channel if it's smaller than the channel.
      That's it.
      http://www.quittintime.com/
      Edited 1/20/2008 12:25 pm ET by calvin
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
