Deck building concept
MichaelNYC | Posted in General Discussion on July 17, 2008 09:41am
I’m going to build a deck (at ground level, completely separate from the house) that’s 12′ deep by 16′ long. I want to fool around with location of the deck, so my plan is to build two 8′ x 12′ rectangles out of 2×8’s — then move them around the yard (joining them together to make the 16′ length) until I find the right area for sun/shade, etc. Then I was going to level these rectangles just a few inches off the ground and mark the corners where the post holes need to be dug. Any reason why this won’t work? Thanks.
  1. Stuart | Jul 17, 2008 10:06pm | #1
    If the purpose of pre-building the frames is so you can better visualize their locations, how about going down to the big box store and getting a couple of those cheapo 8x12 blue plastic tarps?  They only cost a few bucks, will be a lot easier to move around, and you can use them for covering stuff up when you're done.
  2. TomE | Jul 17, 2008 10:48pm | #2
    4 lengths of pvc pipe
    4 ells
    After "deck visualization" is complete you can cut up the pipe later and use for bin storage racks.
    Edited 7/17/2008 3:49 pm ET by TomE
    gdcarpenter | Jul 18, 2008 12:02am | #3
    Have you considered what a built 8'x12' deck would weigh? Moving it around would be no small matter.
    Let's not confuse the issue with facts!
  4. Piffin | Jul 18, 2008 02:05am | #4
    get a couple drop clothes the same size to play around. They are a lot easier to move.
    A deck right on the ground will give you maintanence problems too
  5. Marson | Jul 18, 2008 02:17am | #5
    If it's not attached to the house, and only a few inches off the ground, I wouldn't bother with posts.
