Deck framing question
NSFEddie | Posted in Construction Techniques on June 30, 2005 01:59am
First time questioner:
25 yr old deck outside Denver.
20 ft x 8 ft, about 10 ft in the air.
1 structural member parallel to house,
 measures 20 ft x 13 1/2 in x 4 in, probably pine.
Said member twisting at top, toward house,
 now about 1 1/2 inches out of square.
Can I fix it?
Thanks for your advice.
    dieselpig | Jun 30, 2005 02:07am | #1
    Probably not.
    But I would definately replace it.
    Make a little sketch of what you've got.  Joist and beam sizes, spacing and spans. Locations and dimensions of any posts.  Dimensions of the deck, etc.  and bring it down to a local lumber yard.  I'll bet they'll steer you in the right direction with a prescription for replacing it and give you a stock list with everything you need including the appropriate hardware that will help prevent this drying/twisting effect from reoccuring.
    If it's more than you're up to, they can probably recommend someone who will tackle the job.
    Edited 6/29/2005 7:12 pm ET by dieselpig
    1. NSFEddie | Jun 30, 2005 02:13am | #2
      Thanks.
      I figure it's all gotta go anyway, as there are 0 bolts into the house,
       appears to be all nails.  I can always use the big pieces to build some
       raised garden beds in the backyard......
      1. dIrishInMe | Jun 30, 2005 02:19am | #3
        Really... a 25 yo deck is at the end of it's expected usefull lifetime, assuming it is built of normal materials.  BTW - not sure if you have read about some of the catistrofic deck failures - Chicago comes to mind.  Many (most?) of these indidents involve failure of the ledger board that is connected to the house.
         Matt
  2. mbdyer | Jun 30, 2005 05:16am | #4
    Considering your weather patterns, it's good that things aren't worse.   Sounds like the deck would be a redo.  Nothing lasts forever, eh?
    1. NSFEddie | Jun 30, 2005 06:29am | #5
      Thanks to all for confirming what this used-to-be-a-framer (30 yrs ago)
      thought in the first place.  I have read about the deck failures and have
      kept the load under 4 people since reading about them.  Looks like I have
      a winter project to kept me fit between ski trips.
        JeffBuck | Jun 30, 2005 11:16pm | #6
        well hey ...
        who doesn't love a mid-winter deck job?
        Jeff    Buck Construction
         Artistry In Carpentry
             Pittsburgh Pa
        1. NSFEddie | Jul 01, 2005 01:32am | #7
          Jeff -
           Winter is the best-kept secret here...
          NotSoFastEddie
