deck joist span
BruceT999 | Posted in Construction Techniques on September 5, 2006 07:07am
I’m sure there must have been a string on this, but I tried searching for “deck joist spacing” and found nothing.
Existing deck is 8′ wide with a ledger board and 2×12 joists on 47″ centers supported by 6×6 beams.
To enable replacement of dug fir deck boards with GeoDeck composite, I am adding extra joists on 16″ centers. With 7′ spans, can I use 2×6 or must I go to 2×8?
Thanks in advance
BruceT
  1. MJLonigro | Sep 05, 2006 07:50pm | #1
    Give this link a look..should answer all your ?
    http://www.southernpine.com/spantables.shtml
      BruceT999 | Sep 06, 2006 08:22am | #4
      Thanks for the link. Since I am in CA, I found a similar website with data on the species available to me.http://www.awc.org/calculators/span/calc/timbercalcstyle.aspIt shows that for 100lb/sqft live loads at 16"oc I need 2x8 for my 7' spans. (actually good for up to 8' 7")Thanks guysBruceT
  2. Piffin | Sep 05, 2006 09:11pm | #2
    Snow country winter live loads?
    I'd build with 2x8, but in the south, you might be able to get by with 2x6
  3. kayaker | Sep 06, 2006 01:09am | #3
    Go big or go home!  Just kidding I would go with the larger joist just because of the weight of the decking itself is soo much heavier than dried out wood.
Fast, Accurate Wall Framing
