Deck plank spacing problem
| Posted in General Discussion on May 3, 2005 11:54am
I have a customer with a deck problem where cedar deck planks are too closely spaced approx 1/16 inch. As a result water accumulates in several areas due too poor drainage. Any suggestions for providing water drainage without replacing decking. thanks,ed
    fengelman | May 03, 2005 11:56pm | #1
    how about stacking up a couple of blades in a circular saw, and running them down the middle of the too close spaces?
    1. EdUrbanski | May 03, 2005 11:59pm | #2
      Rick: I was concerned about maintaining a straightline and overall appearance of deck when finished. thanks for advice,ed
      1. FastEddie1 | May 04, 2005 12:07am | #3
        Rick has trhe right idea, or use a router and 1/4" straight bit.  Fasten a straightedge to the deck as a guide.
        CapnMac | May 04, 2005 12:19am | #4
        Do it like you would a router, make up a jig with a couple of guide pins, and put that on the base of the saw.
        There's going to be a hassle almost whatever you do when you get up close to the wall in any event.
        It's tempting to just suggest using a straight fluted bit in the router, and finish up with a chamfering bit--but I'm not the one who gets to knee across the whole deck doing it, so I'm shutting my mouth now <g>.Occupational hazard of my occupation not being around (sorry Bubba)
        1. EdUrbanski | May 04, 2005 05:50pm | #7
          thanks for the advice , I am in agreement ---now to approach the customer----Thanks again,Ed
  2. reinvent | May 04, 2005 12:55am | #5
    In my mind this would be a good excuse to by the EZ saw guide. Just drop it over the gaps and go.
  3. DanH | May 04, 2005 01:05am | #6
    If it's a new deck, just wait a year or two. The boards will shrink in width.
