Decorative floor tile pattern
| Posted in Construction Techniques on June 2, 2004 05:22am
Client is talking about putting a pattern in the new floor tile of the main entry.  The field tile will be 18″ travertine, and she is thinking about insetting a compass rose or similar.  Where can I find a pattern for the rose?  I have seen a picture of it in a tile book, but it is an oblique angle and would be difficult to scan.  I would really like to have something dimensioned, or even better an Autocad file 🙂
Whenever you are asked if you can do a job, tell’em “Certainly, I can!”  Then get busy and find out how to do it.  T. Roosevelt
  1. maverick | Jun 02, 2004 05:31am | #1
    Look on a nautical chart. Take it to Kinkos. They will blow it up to any size you want.
    Edited 6/1/2004 10:34 pm ET by maverick
    1. FastEddie1 | Jun 02, 2004 05:34am | #2
      Yeah, that's the look (depending oin the actual pattern)...but I don't have a nautical chart.  Guess I could buy that boat I've always wanted...that would be a good excuse to get a chart.
      Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
      1. maverick | Jun 02, 2004 05:41am | #3
        Do you have autocad? I might have a similar file. will look tomorro
  2. UncleDunc | Jun 02, 2004 06:34am | #4
    Google for it.
    http://images.google.com/images?q=%22compass+rose%22&hl=en&lr=&ie=UTF-8&sa=N&tab=wi
    If you find a picture you like and don't have a printer, download it, copy it to a disk, and take it to Kinko's or wherever. Here's a nice one I found on the second page of results.
    http://www.davincis.org/images/stone%20medallions%20and%20boarders/Medallions/compass%20Rose%20B%20title.jpg
    Edited 6/1/2004 11:36 pm ET by Uncle Dunc
    1. FastEddie1 | Jun 02, 2004 03:09pm | #5
      After I posted the question, I started searching and found some interesting stuff.  Quilt patterns, for example.  And there's an interesting page from Canada 99's (apparently some type of auxiliary pilots group) that has detailed instructions on how to lay out a compass rose on a runway...a bit larger than I need, but very informative.
  3. BMan | Jun 02, 2004 07:37pm | #6
    Many tile manufacturers offer custom tile pattern setting. They will waterjet cut the pattern and mount the pieces on backing for you to install. You would still have to give them a pattern to work to, though. Check the commercial side of American Olean.com/ design services.
