Dimmer switch causing a hum
CeltsFan | Posted in General Discussion on July 6, 2008 10:33am
We have a pretty standard five light chandelier, 5X75 watt incandescent bulbs. I installed a dimmer switch, the kind that looks like a normal single pole toggle switch, but has the little dimmer switch on the side.
Unfortunately, now the light has a noticeable hum whenever the light is dimmed. There is no hum if the power is all the way up, but less than that, it’s really pretty loud.
Any solutions for this? Different bulbs? Is a bulb loose? Newer bulbs (the ones in there are older)?
    MarkH | Jul 06, 2008 10:37pm | #1
    http://www.lutron.com/product_technical/faq.asp#OLE_LINK12
  2. CeltsFan | Jul 06, 2008 10:38pm | #2
    Best solutions I can find through searching the web are:
    1) Replace bulbs with "rough service" bulbs which supposedly have a thicker filament that doesn't vibrate as much.
    2) Replace bulbs with lower wattage bulbs
    3) Don't dim the light
    4) Wear earplugs
  3. jeffwoodwork | Jul 06, 2008 11:29pm | #3
    Is it a tune you can sing to?
  4. MSA1 | Jul 06, 2008 11:36pm | #4
    Celtsfan, turn up the game.
  • Fine Homebuilding's Author Guidelines
