I used Super Seal dimple membrane around the walls of my ICF basement last fall.
It is a heavy duty product, fairly durable but that means it doesn't stretch well around corners if the footer is wider than the wall. The trim strip is JUNK!! I used a ton of 4 prong hard plastic screw grips and then lapped the top with flashing. It is ugly but not as ugly as the ICF. Hoping that shrubbery hides the grade transition in a few years.
good way to provide a drainage plane to the perimiter drain. Yes have used it and in some very wet soils.
