direct vent FP through offset fire wall?
rickchem | Posted in Construction Techniques on March 22, 2008 06:47am
Townhome has a 8 foot offset from the adjacent townhome.  Double core firewall extends entire length of offset.  Can an exhaust for a direct vent fireplace be pushed through this sidewall?
I’ve searched but have not come up with an answer yet- not just code but true safety as well.
  1. DaveRicheson | Mar 22, 2008 11:41pm | #1
    bump
  2. DanH | Mar 23, 2008 02:21am | #2
    Wouldn't you be pushing the vent into the other townhome?
    1. DaveRicheson | Mar 23, 2008 04:48pm | #3
      Dan, I thinking it is stepped or offset wall. He is going to end up outside, I think. The question(s) seems to be penetrating a rated wall assembly and (my guess) proximety of the vent  windows, doors, etc, of both units.
      1. DanH | Mar 23, 2008 05:21pm | #4
        Yeah, and I'm guessing it would give a code guy conniptions.
        1. rickchem | Mar 24, 2008 03:45am | #5
          That's correct- the rear wall of one house is bumped out 8 ft from the other.   The vent would be to the exterior, but since the firewall is run the whole length of both houses, not just the areas where they adjoin, it would be through the firewall.
          1. DanH | Mar 24, 2008 03:53am | #6
            You're required to have a firewall where the two structures are closer than X feet to each other.  If X were 5 feet then you could probably get away with a flue penetration in the outermost 3 feet.  But I'm guessing that X is more like 10 feet and you're SOL.
Drafting the 2027 IRC
  • The New Old Colonial
