Discovered a voltage tester trick
McDesign | Posted in General Discussion on January 10, 2007 04:17am
Maybe it’s well-known?
I work in old houses a good bit, and often on the old two-wire electrical systems it’s not immediately clear which is the hot and which is the neutral, short of finding a ground somewhere.  Often both wires are black
BUT – I found that the little neon tester in my tool pouch can work.  I hold one lead, and put the other lead on the suspect wires in turn.  If it’s pretty dim inside, I get a faint glow from the tester on the hot wire!
Don’t feel nuthin’
Forrest – can make a lightbulb in my mouth light up
  1. DonCanDo | Jan 10, 2007 04:48am | #1
    A non-contact voltage tester works too.  And it's probably a little easer to read.  Here's an example: http://www.amazon.com/GB-GVD-504A-Circuit-Non-Contact-Voltage/dp/B00004WLKP
    -Don
    1. Mooney | Jan 10, 2007 04:52am | #3
      I use one of those and Design should invest in one .
      Tim
    2. ronbudgell | Jan 10, 2007 05:04am | #5
      I used to have one of those GB brand testers. POS
      Buy greenlee
      Ron
    MarkH | Jan 10, 2007 04:49am | #2
    Old trick, but a good one.   Don't ever try that with a wiggy.  No sir.  Don't ask how I know that.
      bstcrpntr | Jan 10, 2007 04:59am | #4
      I think I tried it with my wiggy and got nothing so went back to mc's trick.
      maybe i'm mistakenthoughFriends help you move.
      Real friends help you move bodies!
        MarkH | Jan 10, 2007 05:22am | #6
        Probably weren't grounded good.  If you are grounded well, it will give you a jolt.
      McDesign | Jan 10, 2007 05:38am | #7
      Umm. . . DW says I should go ahead and ask; not to be intimidated.
      What's a wiggy?  Please God don't let it be dirty - I don't want to get "the letter"
      Is it when your hair stands up on end?
        bstcrpntr | Jan 10, 2007 06:22am | #11
        Name brand of a tester.
        I don't think we will get banned for that, but wedgie...........Friends help you move.
        PaulBinCT | Jan 10, 2007 06:40am | #12
        A Wiggy is a particular brand of tester aka a "solenoidal tester"... it has a solenoid buzzer that gives you a vibrating indication as well as providing a higher load on the circuit being tested (avoids false phantom voltage readings).
        HTH
        PaulB
  3. DanH | Jan 10, 2007 05:54am | #8
    Of course the tester will often light up on a disconnected wire as well.
    Half of the harm that is done in this world is due to people who want to feel important. They don't mean to do harm but the harm does not interest them. --T.S. Eliot
      McDesign | Jan 10, 2007 05:59am | #9
      How could a neon tester get any power from a disconnected wire?  Or you mean a NC?
      1. DanH | Jan 10, 2007 06:01am | #10
        I mean a wire that isn't connected at either end. If it happens to run in the same romex as a "hot" wire, the capacitive pickup is often enough to light the tester.
