I am having garage doors and openers installed. Doors are 8×7.
Where do I install the outlets for the openers?
i'd go back at about 9' from front wall and off center a foot.that way you can use it to plug a hanging drop cord etc into. the door opener should have about a 2' cord with it.
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T
MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE
DUCT TAPE.
Just put it on the sidewall and run some #16 extension cord to it.That's a favorite in Toledo, and gives the HI something to bitch about <G>
"Ask not what the world needs. Ask what makes you come alive... then go do it. Because what the world needs is people who have come alive."
Howard Thurmanhttp://rjw-progressive.blogspot.com/
Thanks for the off center suggestion. It meant more than the distance from header.
Dallas
Not sure if there's that much difference with garage door hdwr, but with my 9' door the outlet is back 2'-6'' more than door ht.. so 11-6''.
Puts it just past the motor.
http://www.quittintime.com/
if you can wait till this afternnon I'll stop by and help you
I can wait but I don't have any conduit. Still got wire.
Look forward to it. Miss your visits. Still working the hours?
got a bit of both, I'll be there around 3 OK ?retired now, can you believe that ?
3 is fine. Retired, how lucky. Invested that big money right.
I have 3 years after yesterday to retire. 6000 hrs. to go.
okey dokey !.
cieling....
about 8-9 feet back and centered on the RO....
WOW!!! What a Ride!
Yes the ceiling. so I have 8-9 or 9 or 10'6''.
Be safe at 9'6"?
we'll just put in 8 boxes ........ hahahahaha.
9'6"
WOW!!! What a Ride!
we're gonna fix him up, I found a roll of jap wrap, 337' of zip cord in various colors, a bunch of .29¢ receps, and some rusty romex staples,.
Don't forget masking tape to wrap where you twist the wires together and when you connect one length of zip cord to that old extension cord, be sure to push the wires through the little holes in the blades before taping them. :)BruceT
Edited 4/18/2009 3:41 pm by brucet9
those are all good... heading there right now !.
man code says duct tape...
WOW!!! What a Ride!
All right except I have some of the old canvas type black tape.
You have friction tape? I haven't seen that stuff since I was a kid and wrapped it around my bat handle for better grip.BruceT
keep those expensive recpts...
got some nickel flea market federal pacifics....
WOW!!! What a Ride!
but I don't know Doodabugs favorite colour. turquoise, mauve, fuschia ........
Purple
the customer is always right :)
no matter....
spray paint....
WOW!!! What a Ride!
ya know, Krylon makes paint for plastic furniture, it could work.
dollar store made in china....
49 cents a case...
WOW!!! What a Ride!
could make a bundle using those.
sure could...
love P&O andmargin...
so what are we gonna soa... er charge him...
WOW!!! What a Ride!
Doodabug had all the done all the prep, all I had to do was bend pipe, he installed it, we pulled the wire, hooked up three outlets. about 30' of pipe..... 40 mins ..... don't charge my friends.
darn....
WOW!!! What a Ride!
Yep, sounds like ya got everthin' ya need!
JimNever underestimate the value of a sharp pencil or good light.
hey are the garage guys done yet ?.
Yes they were done about 1 Monday. Everything worked out great.
The outlets are about halfway between open door and closer head.
Being off center 1' was also a good plan that a couple guys on here mentioned doing.
Being off center is more important than the distance from the header the way I see it now.
Thanks for all your help before and now. Dallas
anytime D, I'll swing by and play with the buttons, say Hi to Barb for me.
I ended up about 9' back because of a scuttle hole in the ceiling. Worked out fine. Thanks
In the garage.
yes
I don't know why you are using that expensive zip cord.I have some bailing wire that I use..
I have been saving lamp cords for years. Just tape them together and good to go.
oh go ahead and tell them what we did....:).
modified knob and tube ....
or do we hold on the knobs and tubes????
WOW!!! What a Ride!
I always put them 11' back in the center of the opening. Works every time!
Actually it's probably better to put it slightly off-center. You don't want the outlet to end up right above the opener where it's hard to reach.
Yes,I think off center 1' was the way to go.
Actually the rear of the motor is about 10' from the door so if you put the outlet at 11' it will be fine. I've been doing this for about 35 years.
Depends on how tall the door is.
Thats why we are speaking of a 7' tall door.
