Does anyone have any feed back on the virutex door planer? I need to get a door planer now.THe virutex looks more balanced than the porter cable but I dont know anyone that has owned one. ANYONE????????????
![](https://images.finehomebuilding.com/app/uploads/2024/07/16151624/01232580-building-matters-expect-unexpected-thumb-16x9.jpg)
Don't buy in to the TV show nightmares—when you uncover something unforeseen on a remodeling project, take these steps to keep the process moving and fix the issue.
Here's a little bump for you...
I prefer my Bosch 1594 but then again I have never used either of the ones you are asking about.
On another note, welcome to BT, I saw that you posted the same question twice, give the first post some time to get some responses. Most of the active posters and readers don't get on till the evening and sometimes it can take a couple of days to get several posts on a thread. Also try searching the archives, portable planers have been discussed at length so hit the advanced search button and search portable planers.
-day
I have used th pc and it works fine but the blade in the one I used had a helical blade that looked expensive to sharpen.
I'm very happy with the Bosch electric plane for about $120.00
Thanks to every one for the words and the bump,(whatever thats all about) Ill check the archives and check back later.
glue
The bump is to keep your post near the top so others will see it and respond. Rez be the bump master! I think he gets some dividends directly related to the no. of times he posts.
I have the PC and like it a lot. I dont remember the cutter being that expensive to sharpen, cant remember exactly how much but it must not be all that bad cause it doesnt stick out in my memory.
Edit, sorry rez, mispelled "bumb/bump!
Edited 3/28/2007 8:57 pm ET by DougU
Got it, thanks for the bump.I appreciate the feed back. Everyone I know has the 9118 P.C. but the virutex looks-via internet-more balanced.wondering if anyone has used it or both- or others. Thannks
Rez be the bumb master
Hope he doesn't take offense at that."Put your creed in your deed." Emerson
My bad, I put that "p" in there upsidedown!
Gotta go edit
Wazza matter with a belt sander?
Or is the door sticking due to weak or slightly pulled hinges? Maybe that's where the problem is?
replacing new slabs in old jambs. I find a planer to be a little more stable and fine tune it with a belt sander if needed.
