dormer flashing question
harvester | Posted in Construction Techniques on November 24, 2006 06:16am
I am roofing a new house that has a number of dormers.  I want to minimize the look of the flashing at the face of the dormer, where it projects from the roof.  Someone described to me how I could flash it and then butter up the flashing with roofing tar, then install a final cut course of shingles over the flashing.  Will this work, or am I inviting leaks and blown off shingles.   The roof is a 14 pitch if that matters much.
    Sphere | Nov 24, 2006 03:27pm | #1
    Do not go adding gobs of tar. It makes the real roofers leak detection that much harder and also eats away at some flashings.
    I have irriatable Vowel syndrome.
  2. MikeSmith | Nov 24, 2006 03:48pm | #2
    we use a painted coil stock break flashing
  3. Piffin | Nov 24, 2006 04:10pm | #3
    That can work but not with the tar gobblets.
    Run shingles until the top of one is nigh to th eface wall.
    Then run a backup of bituthene or Vycor over the shingle and up onto the sheathing 8".
    Now install the apron flashing. Then shingle over it.
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
