In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
DriCore question
User avatar
GotAll10 | Posted in General Discussion on October 17, 2006 03:36am
My basement is dry and has concrete floor and walls.  I’d like to put DriCore or Sub-Flor on the floor and build stud walls inside the concrete block.  My question is:  Do I put the floor down first and build the walls on top of it, or should I build the walls and then the floor inside the walls?
Thanks for the help.
Paul
  1. averagejoe | Oct 17, 2006 04:00pm | #1
    Put the floor down first, and then build the walls on top of it. You also may want to look at another option, depending on how much of a DIYer you are. Lowes now sells Delta FL, which used to only be available from certain contractor supply places. It's a dimple sheet that comes in rolls. You put a T&G subfloor on top of it which has to be screwed through to the concrete with tapcons or similiar. Don't even think of trying to drill all the holes without a real hammer drill.
    It's much faster than Dricore or Subfloor, and cheaper to boot.
Industry-First Cordless Rebar Cutter and Bender
A brushless motor and 36v batteries power Metabo HPT’s cordless rebar bender and cutter.
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
  • Track Lighting for Functional Ambiance in Busy Spaces
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
