I need to drill a sink countertop – any suggestions on how I might go about it, successfully?
DME
DME
A small and dated house lends its foundation to a stylish new home with more than twice the space.
use a diamond bit and water on slow speed. Make a template a template with plywood. drill through the plywood and then set it over the location. This will help with wander. Take your time and do not overheat the bit.
Appreciate the advice - have ordered my diamond bit!
I need to drill 4 relatively small holes - 3/8"D x 1/2" deep to accommodate the underside sink clamps, so it shouldn't be too stressful.
It depends on the size of the hole. If you're drilling a 1 3/8" hole for a faucet, a diamond-tipped hole saw is faster than a drill -- you're removing less material. If your slab is granite, not marble, the hole saw has a big edge over a drill.
Thanks for taking the time to reply - have taken in your advice.
consider hiring a pro. it is cheaper that way than if you screw it up.
Thank you ....
D
MArble is very soft. Cuts like butter but it has veins. I'd recommed that you put a piece of masking tape over the area youre going to drill. Can't hurt.
a
Good luck with the drilling.
FYI, our stone fabricator here drills the holes for us. We just supply them with the sink when we place the order.
