Drip Edge Position.
blownonfuel | Posted in Construction Techniques on February 20, 2009 06:16am
How close should the drip edge be to the fascia? Should the kick out at the bottom of the drip edge be touching the fascia or can the drip edge be extended out to keep it from contacting the fascia? I attached a cheezy sketch since I might not be explaining myself correctly.
  1. Piffin | Feb 20, 2009 06:29am | #1
    Not bad at all for cheesy.
    Darn good even
    yes, you want some drip lone free so the water doesn't bleed back down the face.
    if this drip edge has no extend on it, over hang the shingles by a half inch too.
    1. blownonfuel | Feb 20, 2009 06:38am | #2
      Thanks Piffin. I forgot the extend part on my sketch. I'll be going to a local sheet metal shop tomorrow to see if they can fab me up some custom length drip edge. I need a shallow one so it won't cover up much of the trim.
      1. MikeSmith | Feb 20, 2009 06:47am | #3
        you need enough kick so the water can  D-R-I-P.....any contact and capillary action will pull the water back onto the trim/fasciaMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
        1. blownonfuel | Feb 20, 2009 06:56am | #4
          Mike take a look at the bmp.
          1. MikeSmith | Feb 20, 2009 07:15am | #5
            saw it.....  looks like you want a custom shape.... i'd be inclined to use a standard f-styleMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          2. blownonfuel | Feb 20, 2009 07:25am | #6
            Mike what is an "f" style? How would you go about not covering the top of the trim?
          3. MikeSmith | Feb 20, 2009 02:25pm | #7
            your 2d one ( bottom ) is standard F-stylealso see here....http://www.amerimax.com/catalog/pdfs/pgs%2042-46.pdfyou can modify the standard by bending it up...
            or try to get a custom one made like you want
            in the end
            i'd prefer having the drip edge and possibly burying some of the trim than not having the drip edgeMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          4. blownonfuel | Feb 20, 2009 03:53pm | #10
            I like the F8 and F5 styles.
      2. cargin | Feb 20, 2009 04:26pm | #15
        blown
        Be careful that you don't choose looks over functionality.
        If you don't get the water to drip away from your trim, then the trim won't look so good in a few years.
        This is a point of the house takes alot of water. Or a little water alot of the time, which is probably worse.
        Rich
    2. MSLiechty | Feb 20, 2009 07:47pm | #20
      Our home has no drip edge, Thinking when the previous owners re-roofed they did not pull a permit. I will be adding drip cap when I replace the fascia and boxing in the eaves.ML
      1. Hazlett | Feb 21, 2009 03:07pm | #28
        the majority of the house we work on were built in the 1920's, with no drip edge---and no ill effects from it's lack.Now-a-days- with plywood/osb decking- it's a different story
        Stephen
  2. Hazlett | Feb 20, 2009 03:14pm | #8
    you probably don't need anything custom
    around here I would simply ask for aluminum drip edge, narrow face.-- the part on the fascia is a much narrower profile.
    we usually use the wide face-- but the narrow face is handy when the gutter is set too high and the spike and ferules are consistently interfering with the drip edge
    stephen
    1. blownonfuel | Feb 20, 2009 03:58pm | #11
      Stephen I wish it was that easy. When I ask for drip edge they either look at me funny or take me to the wood trim section. When I finally get them to understand what I am talking about they tell me that is the only size they make. They tell me it must be custom made.
    2. mike585 | Feb 20, 2009 04:07pm | #12
      On the subject, I get water damage (mold, peeling paint, then rot if not attended) on the facia underneath each overlapped drip edge joint. I have the F channel style drip edge. I suspect there's some kind of capillary action going on. Would you recommend silicone on the overlap?
      1. Hazlett | Feb 20, 2009 04:16pm | #13
        I have never had a problem like that--- never even seen it on tear-offs of old galv. drip edge and no underlayment. just to be controversial-- I usually put my drip edge down--and then ice gaurd OVER the drip edge--- and then my starter course/first course of shingles over laps the drip edge about 3/4"---- ideally my drip edge never gets wet.Stephen
        1. MikeHennessy | Feb 20, 2009 04:27pm | #16
          "just to be controversial-- I usually put my drip edge down--and then ice gaurd OVER the drip edge"
          I always thought that's the way it was supposed to be done! Better look. . . .
          Here's what Grace says: "Consistent with good roofing practice, install membrane such that all laps shed water." That to me says over the drip edge.
          Then they say: "Place metal drip edges or wood starter shingles over the membrane". Huh?
          Guess I have a lot of drip edge to tear out! ;-)
          Mike HennessyPittsburgh, PA
          1. cargin | Feb 20, 2009 07:11pm | #17
            Mike
            Before we had I&W membrane I would always install my 30lb tar paper 1st, then lay the drip edge over the tar paper.
            At the bottom of the roof the water comes from below (ice damming) and capillary action.
            With tar paper over drip edge, there is nothing to stop the water from wicking uphill.
            That said, most of the damage and staining I have seen over the years is due to high fascia placement or metal edge that doesn't lay flat.
            In the 50s and 60s the fascia (1x8 and no subfascia) around here was laid flush with the top of the 1x8 sheathing boards (somtimes laid too high). Now we lay the plywood over the subfascia.
            I have also encountered water wicking uphill past the I&W that did not seal to the drip edge. In this case they did not use new drip edge (in the reroof) so the old drip edge could have been dirty.???
            I commonly see aluminum rake edge ( we call it ODE) used as a drip edge. It is bent at a 90 degree so that it wants to spring back when used as an eave drip edge. Then it will direct water back under the shingles.
            Best practice would be to have I&W under drip edge and a 6-12" wide strip placed over the drip edge. That's alot of detailing.
            I though you were in the legal profession.
            Rich
          2. MikeHennessy | Feb 20, 2009 07:22pm | #18
            "I though you were in the legal profession."
            Well, I am (though I am loathe to admit it sometimes). But I put myself through school doing rehabs, carpentry, investment properties, etc. Almost stuck with it full time, but at the time, sitting behind a desk seemed an easier way to make a buck. Nowhere near as fun, though. Still do a lot of it on my own dime. So I've done a bit of roofing here & there.
            My Lovely Assistant won't let me do it anymore tho'. She's askeered of heights! LOL!
          3. cargin | Feb 20, 2009 07:31pm | #19
            Mike
            That answers that question.
            I need to learn how to spell. Geesh
            Rich
          4. Hazlett | Feb 21, 2009 03:12pm | #29
            mike, I have seen it detailed both ways-depending on the brand of icegaurd used
            and--- i have seen employees argue vehemently over which is the right way I have come to the position that I will let whoever is installing it install it THEIR way-- they feel they have more controll and input into things---and it is an issue that really doesn't matter that much to me But when I personally do it--- drip edge first---ice gaurd over the top.
            stephen
    Sphere | Feb 20, 2009 03:38pm | #9
    This guy makes custom anything, ya mighta heard of him...
  4. Hazlett | Feb 20, 2009 04:19pm | #14
    maybe you are trying to buy drip edge from a lumber yard???
    try a roofing material supply house--ABC Supply-- or a local house---- they usually carry drip edge in about8 different colors and several different profiles
    but a lumberyard?-- white,maybe brown, and one profile.
    best wishes,
    stephen
    popawheelie | Feb 20, 2009 08:14pm | #21
    I think some air space behind it is a good thing. I've worked with contractors who want everything tight and caulked.
    Having a little gap helps it dry out and if flashing details are done correctly they are what keeps water out.
    Form an aesthetic standpoint I like when there is a shadow line between materials.
    When you hold everything tight and caulk it, the details disappear.
    1. blownonfuel | Feb 20, 2009 10:19pm | #22
      I think I'll leave a gap between the trim and drip edge. Being that I'm in Central Texas and we don't get much rain much less ice or snow, I hope the lack of a "full" size drip edge won't hurt the trim that much.
        popawheelie | Feb 20, 2009 11:05pm | #25
        Did you back prime that trim? Probably a good idea considering it is so fancy.
        1. blownonfuel | Feb 20, 2009 11:10pm | #26
          Yes, back primed, and back painted it also. It's probably overkill but I'll do it anyway.
          Edited 2/20/2009 3:10 pm ET by blownonfuel
            popawheelie | Feb 20, 2009 11:33pm | #27
            Overkill works!
    rjw | Feb 20, 2009 10:50pm | #23
    To some extent, amount of projection depends on wind conditions.
    Fairly windy in my area, especially out in the countryside.
    The projection we can get away with in town might lead to the drip edge getting ripped off by wind outside of town.
    "Ask not what the world needs. Ask what makes you come alive... then go do it. Because what the world needs is people who have come alive."
    Howard Thurman
    1. blownonfuel | Feb 20, 2009 10:55pm | #24
      I'll probably extend it by an 1/8. I hope it holds.
