Drop Ceiling Recessed Lights
maxchase | Posted in General Discussion on December 31, 2007 05:28am
This is an amateur question, but is there such a thing as a recessed light designed specifcially for drop ceilings?  I am hoping to find something I can just cut into the tile like the typical remodel recessed lights.
I assume these probably aren’t best in drop ceiling tiles because of the thickness of the tile.
  1. IamtheWalrus | Dec 31, 2007 05:58am | #1
    Forget about tile thickness,if the lights are supported by only the tile,it'll cause premature sagging.I've seen that in drop ceilings we've torn out.
  2. DanH | Dec 31, 2007 06:40am | #2
    Cans are used in drop ceilings all the time.  The cans used have special brackets that support them on the rails, so they don't put any weight on the tile itself.
    1. IamtheWalrus | Jan 01, 2008 06:35am | #8
      I Know, but I think he was comparing it to reg. remodeling cans which hook only to the drywall/plaster.
  3. calvin | Dec 31, 2007 06:49am | #3
    Juno and probably Halo have susp. ceiling ends on their cans.  They hook over the ceiling metal.
    http://www.quittintime.com/
  4. andyfew322 | Dec 31, 2007 08:45am | #4
    I've used florecent tubes in mine
    It takes studs to build a house
    1. Biff_Loman | Dec 31, 2007 10:19pm | #5
      Troffers, or open style?  The open kind seem to collect dirt and dust on top of the lens.  Troffers are too expensive for my taste.  ;-)
      1. DanH | Dec 31, 2007 10:26pm | #6
        Troffers are too expensive?? What're you using for a ceiling, pieces of cardboard?
      2. andyfew322 | Jan 01, 2008 12:12am | #7
        I don't know, but it has the one that you take out the plastic lense, and can collect flys on it. lots of flys
Drafting the 2027 IRC
  • The New Old Colonial
