TRIM-TEX manufactures the viynl bull-nose, L-bead for the sheetrock returns and a bull nose adapter for your baseboard to butt up to on the floor. I have loaned out my catalog but there is a post in the archives with their toll free number and web address.
Many drywall distributors stock the TRIM-TEX line of products.
We are looking to have rounded edges on the interior window openings in our house, kind of an adobe feel, and skip the wooden casings. However, although I know these types of moldings for drywall applications exist, I don't know much about them. I was just about to order our windows with a 5" jamb to fit our stress-skin panel walls (4 1/2" + 1/2" drywall, which would bring the windows flush to the interior walls. Is this going to cause a problem with the rounded corner moldings on the walls? Should the windows be recessed a bit? Does anybody have any idea what I'm talking about?
Thanks.
*If the windows are installed flush to the inside of the wall cavity there would not be any room for any type of drywall corner bead. I am aware of 3 types of bullnose corners. Plastic, galvanized metal and aluminum with the tape pre-fused over the corner. Our finishers prefer the latter. When using bullnose corners the drywall should be held back 1/2" at the outside corners. Make sure you take into account that your trim man will want more money to make the 2 extra cuts in the base and crown at every outside corner.
*Mark,You could spec a reg. jamb thickness and return the drywall with the bn corner to the jamb. Leave a little reveal on the jamb, hold the drywall return an 1/8th to 3/16th short of the jamb and L-bead it there. The L-bead will give you a crisp edge to mud to. Use tear-away L-bead and it'll keep the jamb clean till you tear-away. Finish any gap with a good grade of caulk. Best of luck.
*TRIM-TEX manufactures the viynl bull-nose, L-bead for the sheetrock returns and a bull nose adapter for your baseboard to butt up to on the floor. I have loaned out my catalog but there is a post in the archives with their toll free number and web address. Many drywall distributors stock the TRIM-TEX line of products.
