I would like to install ceiling drywall over extruded polystyrene (EPS or “Blueboard”). The EPS would be a sandwiched layer between the drywall and the trusses. Several local drywall contractors have expressed concern that the EPS would be too soft and create a wavy ceiling. However I remain unconvinced that it would be a problem since EPS is commonly used under concrete slabs. Any advice?
A full gut remodel brought new life to an 1821 home that had undergone several misguided renovations.
The problem with attaching drywall over Extruded Polystyrene is that where the screws or nails penetrate the drywall, it will also compress a small area around and under each fastener. When you have a vertical line of them at a stud, the sum of the little compression points will give a valley. Also, I would think that fastener pops would be a big problem.
There is a way around this though. You could use a decoupling device, like wood nailers or resilient metal channels (for sound deadening). One side nailes though the foam and truss, the other connects to the drywall. No waves translate through.
Also a CRX fanatic!
XPS does not compress enough to be noticeable at screws, and you want depressions there anyway for a smooth finish. The biggest disadvatage is actuqally finding the stud or chord to screw into.We use strapping at right angles to the framing over the foam panels like your "de-couplijng" suggestion.
Howdy, what's your thoughts on if your doing it why not use Iso instead of eps.
If I'm doing it, it is polyiso with foil face facing in
Thanks for the help!
DocC,
We have done that using 5/8 sheetrock over 1 inch blueboard or Rboard many times with no problem. It's true that the screw adjustment is critical, but that is always true. (we use 2 1/2 galvanized phillips deck screws).
Sheetrocking over plaster ceilings we have put furring strips over the plaster (leveled with shims) and blueboard or rboard then 5/8 sheetrock over that.
We have installed hidden splice boards (9 inch wide x 1/2 x 4 ft with a 1/8 x 1 inch strip stapled to each edge) up behind the blueboard to take care of necessary butt joints.
Blueboard under drywall shouldn't be a problem, but I strap if the foam is thicker than 1". It's a pain using 3" screws for drywall, in my opinion.
zak
"so it goes"
I have done the three inch screw thing , it works , but a major pain in the a$$
I'm glad it's not just me. Even with 1" foam under there, I miss the studs more often than I should.zak
"so it goes"
I would use this product on the ceiling. The InsulPink is 1.5" XPS in 2x8' sheets formed for 1x3's to fit flush. Use high-strength ceiling drywall sheets to minimize waves.
I have done it and use 21/2 inch screws and the plaster washers from McFeely's
I wouldnt want the job unless it was stapped . For me or doing for you , either way . Definately . Remember that .
Tim
On a different note I would use 3/4 strapping to allow a air space behind the drywall , I am a great fan of air space behind areas that could have condensation a air space keeps drywall dry and healthy and free of mold and allows for easy installation.
George
