Dumb question
Richie921 | Posted in General Discussion on November 24, 2008 08:15am
Sorry if this is a dumb question but hey, I’m curious.  I know double vapor barrier equals bad idea.  How come its ok then to put two layers of tar paper on a wall under the siding.  Isn’t the tar paper a vapor barrier? I’m guessing that since some cultured stone manufacturers want 2 layers its not a vapor barrier but I figured I’d ask to truely understand. Thanks.
  1. MikeRyan | Nov 24, 2008 09:11am | #1
    The Mfg. is not putting a double vapor barrier, but a drainage plain.  Assuming that water will always get behind the siding at some point, the 2nd layer is there to allow the water to drain down, not into the structure.
    A double vapor barrier presents a problem when you are trapping moisture between a wall assembly, i.e. a VB inside the building and then outside.
    Luka | Nov 24, 2008 01:37pm | #2
    Tar paper is not a vapor barrier.
    It acts as a drainage plane, but it is not airtight.
    Click here for
    1. Richie921 | Nov 24, 2008 06:01pm | #3
      Gotcha.  I figured they wouldn't call for it if it would present problems. Thanks
  • Tall Deck on a Sloped Lot
