What is the advantage of one or two tanks. I am looking at the Dewalt #D55155 the single tank & the Dewalt #D55153 double tank. They both deliever 4.5 cfm at 100 psi & are oil lubricated. I would be using this from framing to finish. The double tank is around $320 & the single tank is around $350. I live in a ioslated town you can only get to by plane or boat in Alaska so I can’t just run down to the store & find out thanks for the help.
Here is the comparison from DeWalt.
http://www.dewalt.com/us/products/Tool_Detail_Compare.asp
I have the single tank and it is easier to carry around inside. It is narrower and less likely to smack into a door jamb. We have had some cold mornings and it won't start if left out in the cold. I think I saw another post that said it not a problem after it gets some wear.
